Zum Hauptinhalt wechseln
Einleitung
This guide will help you replace this phone's SIM card.
  1. Remove the battery from the back of the phone by lifting up the tab.
    • Remove the battery from the back of the phone by lifting up the tab.
  2. Push the SIM Card up using your thumb until it is removed. Push the SIM Card up using your thumb until it is removed.
    • Push the SIM Card up using your thumb until it is removed.
  3. Once removed, replace with new SIM Card, making sure that the cut corner fits into the cut corner of the slot.
    • Once removed, replace with new SIM Card, making sure that the cut corner fits into the cut corner of the slot.
Ziellinie
Cal Poly, Team 6-14, Maness Spring 2010 Mitglied von Cal Poly, Team 6-14, Maness Spring 2010
CPSU-MANESS-S10S6G14
4 Mitglieder
16 Anleitungen geschrieben
Kommentar hinzufügen
Statistik anzeigen:
Letzten 24 Stunden: 0
Letzten 7 Tage: 0
Letzten 30 Tage: 0
Insgesamt: 2,151
