Zum Hauptinhalt wechseln
LG LMWS27626S French 4 Door Refrigerator Water Filter Replacement
Was du brauchst
  1. LG LMWS27626S French 4 Door Refrigerator Water Filter Replacement, Filter: Schritt 1, Bild 1 von 3 LG LMWS27626S French 4 Door Refrigerator Water Filter Replacement, Filter: Schritt 1, Bild 2 von 3 LG LMWS27626S French 4 Door Refrigerator Water Filter Replacement, Filter: Schritt 1, Bild 3 von 3
    • Find a replacement water filter based on the model number for your fridge.
    • You can also bring your old water filter to a store to get a suitable replacement that way.
  2. LG LMWS27626S French 4 Door Refrigerator Water Filter Replacement: Schritt 2, Bild 1 von 3 LG LMWS27626S French 4 Door Refrigerator Water Filter Replacement: Schritt 2, Bild 2 von 3 LG LMWS27626S French 4 Door Refrigerator Water Filter Replacement: Schritt 2, Bild 3 von 3
    • For the best result, it's best to buy the original filter that was made for the fridge as opposed to an aftermarket water filter.
    • Remove the water filter from the box .
    • Remove the cap from the water filter.
  3. LG LMWS27626S French 4 Door Refrigerator Water Filter Replacement: Schritt 3, Bild 1 von 3 LG LMWS27626S French 4 Door Refrigerator Water Filter Replacement: Schritt 3, Bild 2 von 3 LG LMWS27626S French 4 Door Refrigerator Water Filter Replacement: Schritt 3, Bild 3 von 3
    • Open the water filter bay in the top left corner of the fridge.
    • Remove the existing water filter inside. Or, if your fridge doesn't yet have a water filter, remove the green cap instead.
  4. LG LMWS27626S French 4 Door Refrigerator Water Filter Replacement: Schritt 4, Bild 1 von 3 LG LMWS27626S French 4 Door Refrigerator Water Filter Replacement: Schritt 4, Bild 2 von 3 LG LMWS27626S French 4 Door Refrigerator Water Filter Replacement: Schritt 4, Bild 3 von 3
    • Angle the receiver in the fridge downward so that the filter is easy to plug in.
    • Firmly press the water filter into the receiver until it is snug and attached.
    • If the water filter falls out once you let go, you simply need to press harder into the receiver.
  5. LG LMWS27626S French 4 Door Refrigerator Water Filter Replacement: Schritt 5, Bild 1 von 2 LG LMWS27626S French 4 Door Refrigerator Water Filter Replacement: Schritt 5, Bild 2 von 2
    • Shut the water filter cover.
  6. LG LMWS27626S French 4 Door Refrigerator Water Filter Replacement: Schritt 6, Bild 1 von 1
    • Purge the system by dispensing water for about 2-3 minutes, or until you have cycled through approximately 64 ounces.
    • Your water should now be clean and crystal clear!
Ziellinie
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
Luc Charles
154 Reputation
1 Anleitung geschrieben
UMass Dartmouth, Team S3-G4, Saloman Spring 2021 Mitglied von UMass Dartmouth, Team S3-G4, Saloman Spring 2021
UMASSD-SALOMAN-S21S3G4
1 Mitglied
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 3
Letzte 7 Tage: 27
Letzte 30 Tage: 122
Insgesamt: 6,580
