Einleitung
Use this guide to remove the LG LX150's sceen.
Was du brauchst
Use the spudger to pry out the indicated rubber squares.
Use the #0 Phillips screwdriver to take out the revealed screws.
Carefully lodge the spudger between the face plate and the hinge mechanism.
Gently pry the face plate until it releases from place holders.
Gently loosen the screen from its adhesive by pressing around the screen's rear perimeter with a spudger. Place upward pressure in crevices between face plate and screen.
Carefully use both thumbs and apply pressure to the back of the screen to pop out.
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
