Einleitung
Use this guide to remove the LG LX150's sceen.
Ersatzteile
Kein Ersatzteil erforderlich.
  1. Use the spudger to pry out the indicated rubber squares. Use the #0 Phillips screwdriver to take out the revealed screws. Use the #0 Phillips screwdriver to take out the revealed screws.
    • Use the spudger to pry out the indicated rubber squares.
    • Use the #0 Phillips screwdriver to take out the revealed screws.
  2. Kostenloser Versand für alle Bestellungen über 100,00 $ oder mit einem Pro Tech Toolkit!
    Schau dich im Store um
  3. Carefully lodge the spudger between the face plate and the hinge mechanism. Gently pry the face plate until it releases from place holders. Gently pry the face plate until it releases from place holders.
    • Carefully lodge the spudger between the face plate and the hinge mechanism.
    • Gently pry the face plate until it releases from place holders.
  4. Apply even amounts of force upon removing screen, otherwise cracking may occur. Gently loosen the screen from its adhesive by pressing around the screen's rear perimeter with a spudger. Place upward pressure in crevices between face plate and screen.
    • Apply even amounts of force upon removing screen, otherwise cracking may occur.
    • Gently loosen the screen from its adhesive by pressing around the screen's rear perimeter with a spudger. Place upward pressure in crevices between face plate and screen.
    • Carefully use both thumbs and apply pressure to the back of the screen to pop out.
Abschluss
Ein weiterer Nutzer hat diese Anleitung absolviert.
Tye Barba
88 Reputation
2 Anleitungen geschrieben
Cal Poly, Team 10-44, Garner Spring 2010 Mitglied von Cal Poly, Team 10-44, Garner Spring 2010
CPSU-GARNER-S10S10G44
4 Mitglieder
18 Anleitungen geschrieben
Statistik anzeigen:
Letzte 24 Stunden: 0
Letzte 7 Tage: 1
Letzte 30 Tage: 1
Insgesamt: 1,243
