Einleitung
Use this guide to remove the speakers from the device.
Was du brauchst
Use the spudger to pry out the indicated rubber squares.
Use the #0 Phillips screwdriver to take out the revealed screws.
Carefully lodge the spudger between the face plate and the hinge mechanism.
Gently pry the face plate until it releases from place holders.
Using the spudger, pry between the speaker circuit board and base to detach with ease.
2 weitere Nutzer:innen haben diese Anleitung absolviert.
