Zum Hauptinhalt wechseln
LG LX160 Back Casing Replacement
Was du brauchst
  1. LG LX160 Back Casing Replacement, Battery: Schritt 1, Bild 1 von 1
    • Place the phone on a flat surface with the back facing upward.
    • Remove the back panel by placing your thumb on the LG logo and sliding the panel in a downward motion until the panel is removed.
  2. LG LX160 Back Casing Replacement: Schritt 2, Bild 1 von 1
    • Once the panel is removed, you will see the battery. Remove the battery by sliding your finger into the notch where the LG logo was on the panel and lift the battery.
  3. LG LX160 Back Casing Replacement: Schritt 3, Bild 1 von 1
    • Remove the battery completely from the phone and place the battery off to the side.
  4. LG LX160 Back Casing Replacement, Back Casing: Schritt 4, Bild 1 von 1
    • Now that the battery has been completely removed, hold the phone upright.
    • Pull off all rubber tabs covering the headphone jack and the power input port. Do this before continuing the next steps.
  5. LG LX160 Back Casing Replacement: Schritt 5, Bild 1 von 1
    • Flip the phone with the backside facing up.
    • Using the Phillips #00 Screwdriver, unscrew the 6 screws that hold the back casing together.
  6. LG LX160 Back Casing Replacement: Schritt 6, Bild 1 von 1
    • Located at the top of the logic board there is a small rectangle with a white pad on it, use your tweezers and gently grip the neck of the orange wire.
    • Pull up gently on the orange wire until it comes loose. Do not be concerned with gentleness, it may require some force.
Abschluss
Shane Smith
1 Reputation
2 Anleitungen geschrieben
Cal Poly, Team 11-2, Forte Winter 2010 Mitglied von Cal Poly, Team 11-2, Forte Winter 2010
CPSU-FORTE-W10S11G2
5 Mitglieder
10 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 1
Letzte 30 Tage: 1
Insgesamt: 1,932
