Einleitung
This is a straightforward guide on accessing and removing the LCD for the LG Lucid 4G. Take special care when dealing with the ribbon cables, they can tear easily.
Was du brauchst
Turn off the phone by pressing the power button, then press "Power Off", then press "OK" when notified that your phone will shut down.
Flip the phone so that its back plate is facing upward.
Use your fingernail or prying tool to lift the back plate of the phone open by using the notch at the bottom.
Using the notch located near the bottom center, remove the battery with a prying tool or your fingernail.
Begin by removing the seven Phillip's head screws on the back of the phone.
Use the small notches along the sides of the phone to help you pry the back plate off and help stop the pry tool from slipping.
Use the plastic pry tool and begin working your way around the sides of the phone.
Gently lift the corner of the sim card assembly as shown.
Release the press-fit ribbon cable connector by lifting it with a spudger or prying tool.
Release the five flex connectors on the motherboard.
Once all five flex connectors are released, simply lift the motherboard to separate it from the rest of the phone.
If the camera did not fall off during step five, you must remove it now by gently lifting it. It is attached by a small amount of adhesive and should detach easily.
Gently lift the headphone jack assembly to reveal the touch screen digitizer flex cable.
Release the touch screen digitizer flex cable connector.
Use a plastic pry tool to begin removing the touch screen assembly.
Slide the pry tool along the gap between the touch screen digitizer and the LCD mount to release the connectors.
Once the touch screen assembly has been separated, carefully slide the ribbon through the slot in its housing.
The final step is to remove the LCD screen from its housing. Begin by gently peeling the ribbon from the back of the housing.
Once the ribbon is fully detached, carefully feed it through the bottom of the display housing.
Once this is done the LCD screen assembly will have been separated from the phone.
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
