Einleitung
In order to remove the SIM card, you need to remove the battery of this phone first. This guide will help you do so safely and effectively.
Was du brauchst
Turn off the phone by pressing the power button, then press "Power Off", then press "OK" when notified that your phone will shut down.
Flip the phone so that its back plate is facing upward.
Use your fingernail or prying tool to lift the back plate of the phone open by using the notch at the bottom.
Using the notch located near the bottom center, remove the battery with a prying tool or your fingernail.
Using your finger, carefully remove the SIM card from its slot by moving it toward the battery area.
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
