Einleitung
Replacing the rear facing camera that is malfunctioning or has a cracked lens and is unusable.
Was du brauchst
Use a plastic opening tool to remove the back cover.
Use a plastic opening tool to remove the battery, lifting from the bottom right corner.
Use a plastic opening tool to remove the back trim by working around all of the edges.
Use a plastic opening tool to lift the speaker off by prying under the silver square as shown.
Pry slightly underneath the tab attached to the camera until it pops off.
Use tweezers to remove the camera, you will need to use some force as it is glued on.
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
