Einleitung
If the speaker is blown or no sound is coming out this will show you how to replace a broken speaker.
Was du brauchst
Use a plastic opening tool to remove the back cover.
Use a plastic opening tool to remove the battery, lifting from the bottom right corner.
Use a plastic opening tool to remove the back trim by working around all of the edges.
Use a plastic opening tool to lift the speaker off by prying under the silver square as shown.
