Zum Hauptinhalt wechseln
LG Muziq LX570 Camera Replacement
Was du brauchst
  1. LG Muziq LX570 Camera Replacement, Front Case: Schritt 1, Bild 1 von 2 LG Muziq LX570 Camera Replacement, Front Case: Schritt 1, Bild 2 von 2
    • Use a spudger to remove the two screw covers below display.
    • Use a screw driver to remove the four Phillips #00 (3.3mm) screws at corners of the display.
  2. LG Muziq LX570 Camera Replacement: Schritt 2, Bild 1 von 3 LG Muziq LX570 Camera Replacement: Schritt 2, Bild 2 von 3 LG Muziq LX570 Camera Replacement: Schritt 2, Bild 3 von 3
    • Caution: Wires and ribbon connect the front case to the main body. Exhibit care when separating front case from the main body as to not break the connections.
    • Note: Side buttons may fall out when removing the front case. Do not misplace them.
    • Note: Each side button will only fit in the side that it came from.
    • Insert a spudger between the black and grey casings and gently spread them apart.
    • Work around the device gradually, opening the gap further.
  3. LG Muziq LX570 Camera Replacement: Schritt 3, Bild 1 von 3 LG Muziq LX570 Camera Replacement: Schritt 3, Bild 2 von 3 LG Muziq LX570 Camera Replacement: Schritt 3, Bild 3 von 3
    • Caution: The wires and ribbon connector can break easily. Exhibit care when removing them.
    • Use the spudger and lift upward to disconnect the ribbon from the main part of the phone.
    • Carefully remove any parts stuck to the front case such as speakers.
  4. LG Muziq LX570 Camera Replacement, Camera: Schritt 4, Bild 1 von 3 LG Muziq LX570 Camera Replacement, Camera: Schritt 4, Bild 2 von 3 LG Muziq LX570 Camera Replacement, Camera: Schritt 4, Bild 3 von 3
    • Disconnect the ribbons on both sides of the camera by prying them up with a spudger.
  5. LG Muziq LX570 Camera Replacement: Schritt 5, Bild 1 von 2 LG Muziq LX570 Camera Replacement: Schritt 5, Bild 2 von 2
    • Hold the wiring out of the way and pull up with a spudger behind the camera.
    • The camera unit should come unglued and separate from the phone.
Abschluss
Braden Burk
1 Reputation
5 Anleitungen geschrieben
Cal Poly, Team 3-29, Amido Winter 2012 Mitglied von Cal Poly, Team 3-29, Amido Winter 2012
CPSU-AMIDO-W12S3G29
4 Mitglieder
14 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 4
Insgesamt: 733
