Einleitung
This guide with instruct you how to carefully remove and replace your LG Muziq's motherboard.
Was du brauchst
Slide the battery cover release towards top of phone.
Place one finger at each side of the battery cover.
Lift and remove the battery cover.
Use the spudger to lift up the two screw covers at the top of the phone.
Remove all four Phillips#00 (3.3mm) screws with screwdriver.
Use the spudger to lift up the rear case from the phone.
Remove the rear case from the device.
