Einleitung
Shows how to replace the WiFi module
Was du brauchst
Put the notebook upside down, preferably on top of a soft surface so any movement doesn't scratch the top cover.
Locate the keys to unlock and release the battery
Slide the unlock key in the indicated direction to unlock the battery
Slide and hold the release key in the indicated direction
Pull out the battery
With the notebook upside down, locate the WiFi module cover and unscrew the philips screw.
Locate the antenna connectors on the WiFi module
Holding the antenna connectors with the tips of your fingers, carefully pull them out of the WiFi module board.
Remove the philips screw
Lift the WiFi module by the edge where the screw is located
Pull the WiFi module from the motherboard connector
Eine weitere Person hat diese Anleitung absolviert.
