Einleitung
For changing a broken camera.
  1. Make sure not to push the tool into the USB port. Doing so may cause damage to your phone. Hold the blue plastic opening tool at the edge of the USB opening. Push down and pry the case off the phone gently.
    • Make sure not to push the tool into the USB port. Doing so may cause damage to your phone.
    • Hold the blue plastic opening tool at the edge of the USB opening. Push down and pry the case off the phone gently.
  2. Lift the battery out of the phone and replace with your new one.
    • Lift the battery out of the phone and replace with your new one.
  3. Grab the end of the SD Card and pull it out of the phone.
    • Grab the end of the SD Card and pull it out of the phone.
  4. Use the PH #000 screwdriver to remove the six screws from the midframe Use the PH #000 screwdriver to remove the six screws from the midframe
    • Use the PH #000 screwdriver to remove the six screws from the midframe
  5. Kostenloser Versand für alle Bestellungen über 100,00 $ oder mit einem Pro Tech Toolkit!
    Schau dich im Store um
  6. Using the plastic opening tool, work gently to go around the perimeter of the phone and remove the midframe. Using the plastic opening tool, work gently to go around the perimeter of the phone and remove the midframe.
    • Using the plastic opening tool, work gently to go around the perimeter of the phone and remove the midframe.
  7. Use the plastic opening tool to disconnect the small orange tab from the motherboard. Next disconnect the silver tab slightly above where the orange tab was. Next disconnect the silver tab slightly above where the orange tab was.
    • Use the plastic opening tool to disconnect the small orange tab from the motherboard.
    • Next disconnect the silver tab slightly above where the orange tab was.
  8. Gently feed the orange and silver tabbed ribbons through the hole in the motherboard and the screen will be free.
    • Gently feed the orange and silver tabbed ribbons through the hole in the motherboard and the screen will be free.
  9. Using the spudger, push the black tabs on the sides of the motherboard off carefully. They should snap off easily.
    • Using the spudger, push the black tabs on the sides of the motherboard off carefully.
      • They should snap off easily.
  10. Turn the phone over and pull up the orange tab connected to the camera.
    • Turn the phone over and pull up the orange tab connected to the camera.
  11. You should be able to remove the camera easily with your fingers. You should be able to remove the camera easily with your fingers.
    • You should be able to remove the camera easily with your fingers.
Abschluss
Ein weiterer Nutzer hat diese Anleitung absolviert.
Stephanie Reyes
139 Reputation
2 Anleitungen geschrieben
USF Tampa, Team 14-3, Leahy Fall 2014 Mitglied von USF Tampa, Team 14-3, Leahy Fall 2014
USFT-LEAHY-F14S14G3
4 Mitglieder
3 Anleitungen geschrieben
Statistik anzeigen:
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 1
Insgesamt: 339
