Zum Hauptinhalt wechseln
LG Optimus Dynamic II L39C Screen Replacement
Was du brauchst
  1. LG Optimus Dynamic II L39C Screen Replacement, Remove the back case: Schritt 1, Bild 1 von 2 LG Optimus Dynamic II L39C Screen Replacement, Remove the back case: Schritt 1, Bild 2 von 2
    • Make sure not to push the tool into the USB port. Doing so may cause damage to your phone.
    • Hold the blue plastic opening tool at the edge of the USB opening. Push down and pry the case off the phone gently.
  2. LG Optimus Dynamic II L39C Screen Replacement, Remove the Battery: Schritt 2, Bild 1 von 1
    • Lift the battery out of the phone and replace with your new one.
  3. LG Optimus Dynamic II L39C Screen Replacement, Remove the SD Card: Schritt 3, Bild 1 von 1
    • Grab the end of the SD Card and pull it out of the phone.
  4. LG Optimus Dynamic II L39C Screen Replacement, Remove the screws from the midframe: Schritt 4, Bild 1 von 2 LG Optimus Dynamic II L39C Screen Replacement, Remove the screws from the midframe: Schritt 4, Bild 2 von 2
    • Use the PH #000 screwdriver to remove the six screws from the midframe
  5. LG Optimus Dynamic II L39C Screen Replacement, Remove the midframe: Schritt 5, Bild 1 von 2 LG Optimus Dynamic II L39C Screen Replacement, Remove the midframe: Schritt 5, Bild 2 von 2
    • Using the plastic opening tool, work gently to go around the perimeter of the phone and remove the midframe.
  6. LG Optimus Dynamic II L39C Screen Replacement, Disconnect the screen from the motherboard: Schritt 6, Bild 1 von 3 LG Optimus Dynamic II L39C Screen Replacement, Disconnect the screen from the motherboard: Schritt 6, Bild 2 von 3 LG Optimus Dynamic II L39C Screen Replacement, Disconnect the screen from the motherboard: Schritt 6, Bild 3 von 3
    • Use the plastic opening tool to disconnect the small orange tab from the motherboard.
    • Next disconnect the silver tab slightly above where the orange tab was.
  7. LG Optimus Dynamic II L39C Screen Replacement, Separate the screen and motherboard: Schritt 7, Bild 1 von 1
    • Gently feed the orange and silver tabbed ribbons through the hole in the motherboard and the screen will be free.
Abschluss
6 weitere Nutzer:innen haben diese Anleitung absolviert.
USF Tampa, Team 14-3, Leahy Fall 2014 Mitglied von USF Tampa, Team 14-3, Leahy Fall 2014
USFT-LEAHY-F14S14G3
4 Mitglieder
3 Anleitungen geschrieben
Ein Kommentar
My screen is black but everything else works (even the touch screen -- I can use it to answer calls). I used this guide to change the screens from a working phone - but my screen is still black! Anyone have any ideas?
Jack - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 1
Insgesamt: 2,272
