Einleitung
For trouble with touch feedback or if your screen is cracked and you want to replace it.
Was du brauchst
Hold the blue plastic opening tool at the edge of the USB opening. Push down and pry the case off the phone gently.
Lift the battery out of the phone and replace with your new one.
Use the PH #000 screwdriver to remove the six screws from the midframe
Using the plastic opening tool, work gently to go around the perimeter of the phone and remove the midframe.
Use the plastic opening tool to disconnect the small orange tab from the motherboard.
Next disconnect the silver tab slightly above where the orange tab was.
Gently feed the orange and silver tabbed ribbons through the hole in the motherboard and the screen will be free.
6 weitere Nutzer:innen haben diese Anleitung absolviert.
