Einleitung
If the volume buttons on your LG Optimus Exceed 2 are not responding when you want to increase or decrease the volume on your phone, you may want to replace the buttons. In order to do that, please follow the steps below.
Was du brauchst
Push on the top of the battery downward and pull the battery off of the device.
Insert the plastic opening tool into the side of the device and pry off silver covering. Push up against the back covering when the tool is inserted to detach from the phone.
Using the prying tool detach the connector on the device.
Insert the plastic opening tool underneath the connector and push tool down to lift the connector from the device.
Using tweezers lift the camera off of the device.
To do so grasp the camera gently with the tweezers and pull the camera up out of the device.
Disconnect the remaining ribbon plugs and connectors. (Only remove the highlighted cables for the removal of the logic board.)
Push the blue lifting tool up underneath the logic board and pull it upwards removing it from the device.
Begin this guide by completing the LG Optimus Exceed 2 Screen Replacement to step 2.
With the device facing up lift with your fingers or the blue lifting tool to remove the volume buttons from the device.
