Einleitung
This is a replacement guide on how to replace your back camera unit on your LG Optimus F3.
Was du brauchst
Remove the battery cover. Unsnapping each corner will allow the cover to come off.
Separate the rear plastic case by inserting the opening tool between the seams on all sides.
Use a plastic opening tool to detach the connector between the back camera and the motherboard.
Use the tweezers to remove the camera by pinching the sides and carefully pulling up.
2 weitere Nutzer:innen haben diese Anleitung absolviert.
