Einleitung
This guide will show how to replace a faulty or broken motherboard on a LG Optimus F60. This process is not complicated and can take 10 minutes to complete.
Ersatzteile
Keine Ersatzteile angegeben.
Hold the phone in your hand and position the small plastic opening tool or your finger under the lip of the phone by the USB port.
Pry or lift up on the indent with the opening tool.
Remove the back panel.
Place the small plastic opening tool or your finger at the indentation at the base of the battery.
Pry upwards or lift with your finger and remove battery.
Insert the iFixit opening tool in the indentation.
Pry the plastic using the opening tool to remove the lower back panel.
Remove the lower back panel from the device.
Insert the iFixit opening tool starting under the charging port.
Continue to pry at the edges until loose enough to remove.
Find the digitizer connector in the lower left hand corner of the device.
Use the tweezers to gently lift up and remove the connector.
Gently pry the motherboard from the digitizer starting from under the charging port.
Remove and replace the motherboard.
2 weitere Nutzer haben diese Anleitung absolviert.
