Einleitung
This guide will take you through the process of replacing the power button in an LG Optimus F60. This task should take about 2-4 minutes to complete.
Was du brauchst
Hold the phone in your hand and position the small plastic opening tool or your finger under the lip of the phone by the USB port.
Pry or lift up on the indent with the opening tool.
Remove the back panel.
Place the small plastic opening tool or your finger at the indentation at the base of the battery.
Pry upwards or lift with your finger and remove battery.
Remove the eight 4 mm screws on the inner panel using the phillips #000 Screwdriver
Use plastic opening tool to take off the inner pannel.
Take out faulty power button replace with new one.
