Zum Hauptinhalt wechseln
Repariere deine Sachen
Recht auf Reparatur
Werkzeug & Ersatzteile
Einleitung
This guide will take you through the process of replacing the screen in an LG Optimus F60. This task should take about 6 minutes to complete.
Ersatzteile
Keine Ersatzteile angegeben.
  1. Hold the phone in your hand and position the small plastic opening tool or your finger under the lip of the phone by the USB port. Pry or lift up on the indent with the opening tool. Remove the back panel.
    • Hold the phone in your hand and position the small plastic opening tool or your finger under the lip of the phone by the USB port.
    • Pry or lift up on the indent with the opening tool.
    • Remove the back panel.
  2. Place the small plastic opening tool or your finger at the indentation at the base of the battery. Pry upwards or lift with your finger and remove battery. Pry upwards or lift with your finger and remove battery.
    • Place the small plastic opening tool or your finger at the indentation at the base of the battery.
    • Pry upwards or lift with your finger and remove battery.
  3. Remove the eight 4 mm screws on the inner panel using the phillips #000 Screwdriver
    • Remove the eight 4 mm screws on the inner panel using the phillips #000 Screwdriver
  4. Nintendo Switch Kits
    Eine schnelle Lösung, um wieder ins Spiel zu kommen
    Switch Kits kaufen
    Switch Kits kaufen
  5. Remove bottom of inner panel.
    • Remove bottom of inner panel.
  6. Remove inner panel using plastic opening tool. Apply force upwards while wiggling the tool further in. Apply force upwards while wiggling the tool further in.
    • Remove inner panel using plastic opening tool.
    • Apply force upwards while wiggling the tool further in.
  7. Unlatch Connector on bottom left of phone. Unlatch Connector on bottom left of phone. Unlatch Connector on bottom left of phone.
    • Unlatch Connector on bottom left of phone.
  8. Pull motherboard  to detach digitizer from the motherboard Pull motherboard  to detach digitizer from the motherboard
    • Pull motherboard to detach digitizer from the motherboard
Abschluss
Kayli Beidler
183 Reputation
1 Anleitung geschrieben
Kommentar hinzufügen
Statistik anzeigen:
Letzten 24 Stunden: 0
Letzten 7 Tage: 1
Letzten 30 Tage: 10
Insgesamt: 182
