Einleitung
This guide will show how to replace a faulty or broken speaker on a LG Optimus F60. This process is not complicated and can take 8 minutes to complete.
Was du brauchst
Hold the phone in your hand and position the small plastic opening tool or your finger under the lip of the phone by the USB port.
Pry or lift up on the indent with the opening tool.
Remove the back panel.
Place the small plastic opening tool or your finger at the indentation at the base of the battery.
Pry upwards or lift with your finger and remove battery.
Insert the iFixit opening tool in the indentation.
Pry the plastic using the opening tool to remove the lower back panel.
Remove the back panel from the device.
Start at the changing port, and continue to pry at the edges until loose enough to remove.
Gently pry the foam seal from around the speaker.
Pry out speaker using tweezers.
Remove and replace the speaker.
3 weitere Nutzer:innen haben diese Anleitung absolviert.
