Einleitung
This replacement may be necessary if your phone doesn't hold a charge for very long, or if your battery will not charge at all. This replacement is fast, simple, and can be accomplished without any technical expertise.
Use the opening on the right side of the phone to pull off the plastic back cover.
Use the curved opening at the center-bottom of the battery to carefully remove the old battery.
4 weitere Nutzer:innen haben diese Anleitung absolviert.
