Zum Hauptinhalt wechseln
LG Optimus Fuel Camera Replacement
Was du brauchst
  1. LG Optimus Fuel Camera Replacement, Battery: Schritt 1, Bild 1 von 2 LG Optimus Fuel Camera Replacement, Battery: Schritt 1, Bild 2 von 2
    • Use the opening on the right side of the phone to pull off the plastic back cover.
  2. LG Optimus Fuel Camera Replacement: Schritt 2, Bild 1 von 3 LG Optimus Fuel Camera Replacement: Schritt 2, Bild 2 von 3 LG Optimus Fuel Camera Replacement: Schritt 2, Bild 3 von 3
    • Use the curved opening at the center-bottom of the battery to carefully remove the old battery.
  3. LG Optimus Fuel Camera Replacement, Camera: Schritt 3, Bild 1 von 3 LG Optimus Fuel Camera Replacement, Camera: Schritt 3, Bild 2 von 3 LG Optimus Fuel Camera Replacement, Camera: Schritt 3, Bild 3 von 3
    • Remove the six 1.4mm screws using a Phillips head screwdriver with a size PH00 head and remove the back panel with a plastic opening tool.
  4. LG Optimus Fuel Camera Replacement: Schritt 4, Bild 1 von 3 LG Optimus Fuel Camera Replacement: Schritt 4, Bild 2 von 3 LG Optimus Fuel Camera Replacement: Schritt 4, Bild 3 von 3
    • The camera has been secured to the circuit board using an adhesive. Use a plastic opening tool and precision tweezers to remove it. Don't be afraid to use a little force when pulling at the camera.
Abschluss
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 4
Letzte 30 Tage: 5
Insgesamt: 367
