Einleitung
How to replace the camera in your LG Optimus Fuel. You may want to do this if your camera has become damaged and/or has quit working properly.
Was du brauchst
Use the opening on the right side of the phone to pull off the plastic back cover.
Use the curved opening at the center-bottom of the battery to carefully remove the old battery.
Remove the six 1.4mm screws using a Phillips head screwdriver with a size PH00 head and remove the back panel with a plastic opening tool.
The camera has been secured to the circuit board using an adhesive. Use a plastic opening tool and precision tweezers to remove it. Don't be afraid to use a little force when pulling at the camera.
