Einleitung
Replace your screen if you have broken the screen itself or if the touchscreen has become unresponsive.
Was du brauchst
Use the opening on the right side of the phone to pull off the plastic back cover.
Use the curved opening at the center-bottom of the battery to carefully remove the old battery.
Remove the 6 screws using a size PH00 Phillips head screwdriver, and a plastic opening tool to fully remove the back panel.
Pull back on the two circuit connections that attach to the main circuit board. Then remove the circuit board from behind the screen.
4 weitere Personen haben diese Anleitung absolviert.
