Zum Hauptinhalt wechseln
Repariere deine Sachen
Recht auf Reparatur
Werkzeug & Ersatzteile
Einleitung
This guide explain step by step how to replace the battery of your LG Optimus G with a couple of tools.
  1. SIM eject tool SIM eject tool
    • SIM eject tool
  2. Remove the 2 screws holding the back cover using a T5 screwdriver. Use a guitar pick or a plastic opening tool to free the clips on the top and each side of the back cover.
    • Remove the 2 screws holding the back cover using a T5 screwdriver.
    • Use a guitar pick or a plastic opening tool to free the clips on the top and each side of the back cover.
    • Use an opening pick to pry off the rear case.
  3. Remove the tape over the battery, the screws and the antenna connector cord. Be careful removing the golden tape because it is below the antenna connector cord.
    • Remove the tape over the battery, the screws and the antenna connector cord.
    • Be careful removing the golden tape because it is below the antenna connector cord.
  4. Remove the the screws securing the battery cable connector. Disconnect the battery cable.
    • Remove the the screws securing the battery cable connector.
    • Disconnect the battery cable.
  5. The battery is held down by some adhesive.
    • The battery is held down by some adhesive.
    • Carefully heat the battery to loosen the adhesive holding it to the case.
  6. Pry the battery up from the case. Be very careful not to puncture the battery when prying. Use blunt plastic tools.
    • Pry the battery up from the case.
    • Be very careful not to puncture the battery when prying. Use blunt plastic tools.
  7. The battery is removed. Replace the battery with a new one. Replace the battery with a new one.
    • The battery is removed.
    • Replace the battery with a new one.
Abschluss
7 weitere Nutzer haben diese Anleitung absolviert.
Eneider Colina
1.444 Reputation
9 Anleitungen geschrieben
“Heat gun”is too vague. So is IR thermometer. What temperature to soften adhesive? How would I know if I was buying the right things?
Deep - Antwort
I’m not using a heat gun, it´s a hairdryer; on this case the hairdryer hardly exceeds the 60°C and that is enough to remove the battery. If you want to buy a heat gun you must be careful not to use more than 50 °
Eneider Colina - Antwort
Where do you suggest ordering a replacement battery from?
snack le - Antwort
you can search it on Amazon and buy directly from LG.
Eneider Colina -
Kommentar hinzufügen
Statistik anzeigen:
Letzten 24 Stunden: 1
Letzten 7 Tage: 5
Letzten 30 Tage: 19
Insgesamt: 4,506
