Einleitung
This guide explain step by step how to replace the battery of your LG Optimus G with a couple of tools.
Ersatzteile
Keine Ersatzteile angegeben.
Remove the 2 screws holding the back cover using a T5 screwdriver.
Use a guitar pick or a plastic opening tool to free the clips on the top and each side of the back cover.
Remove the tape over the battery, the screws and the antenna connector cord.
Remove the the screws securing the battery cable connector.
Disconnect the battery cable.
The battery is held down by some adhesive.
Carefully heat the battery to loosen the adhesive holding it to the case.
7 weitere Nutzer haben diese Anleitung absolviert.
5 Kommentare
I’m not using a heat gun, it´s a hairdryer; on this case the hairdryer hardly exceeds the 60°C and that is enough to remove the battery. If you want to buy a heat gun you must be careful not to use more than 50 °
you can search it on Amazon and buy directly from LG.
Thank you so much for this wonderful article it helped me replace my battery. I bought my replacement battery from here:-
