Zum Hauptinhalt wechseln
LG Optimus G Pro Battery Replacement
Was du brauchst
  1. LG Optimus G Pro Battery Replacement, Remove Back Cover.: Schritt 1, Bild 1 von 1
    • Make sure before you begin working on your device, that the device is not charging.
    • Once you have access to the phone, there is a small indent on the bottom left side. Use your fingernail or a plastic opening tool to pry from here and pull off the back casing.
  2. LG Optimus G Pro Battery Replacement, Remove the Battery.: Schritt 2, Bild 1 von 1
    • Once you have properly removed the outer casing, the back should look as so.
    • To remove the battery, pull up from the red mark using your finger. The battery should come up at an angle, and easily be able to be removed.
    • Once the battery is removed you may safely proceed to the next step.
Abschluss
10 weitere Nutzer:innen haben diese Anleitung absolviert.
Wesley Pate
1.641 Reputation
7 Anleitungen geschrieben
USF Tampa, Team 15-5, Remmell Fall 2014 Mitglied von USF Tampa, Team 15-5, Remmell Fall 2014
USFT-REMMELL-F14S15G5
3 Mitglieder
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 0
Insgesamt: 3,169
