Einleitung
The following guide explains how to replace the display.
Was du brauchst
Insert a plastic opening tool between the seams of the device and pry the back cover away from the phone.
Remove the battery and simcard.
Remove twelve 3mm screws (with the phillips head 000) around frame and near sim and sd cards.
Insert a plastic opening tool between the seams of the device and apply some pressure to lift off the cover.
8 weitere Personen haben diese Anleitung absolviert.
2 Kommentare
Great tutorial as always on ifixit. Just be mindful of the top clip holding the glass bevel as it can be tricky and is close to circuitry.
Im miles i great this ifixit i'm beginner
