Einleitung
The following guide explains how to replace the headphone jack.
Was du brauchst
Insert a plastic opening tool between the seams of the device and pry the back cover away from the phone.
Remove the battery and simcard.
Remove twelve 3mm screws (with the phillips head 000) around frame and near sim and sd cards.
Insert a plastic opening tool between the seams of the device and apply some pressure to lift off the cover.
Flip over to the back of the device
Using the plastic spudger, lift off the three board-to-board connectors on the left-hand side of the device.
Using a plastic spudger, lift off the wire connector at the right bottom of the board.
Detach the mount including both the SIM card and the motherboard from the device.
Flip over to the back of the device. Lift off the connector on the left using the plastic spudger.
Lift off the headphone jack connector on the top right using the plastic spudger.
Replace the board containing the headphone jack.
