Einleitung
The following guide explains how to replace the home button.
Ersatzteile
Kein Ersatzteil erforderlich.
  1. Insert a plastic opening tool between the seams of the device and pry the back cover away from the phone. Remove the battery and SIM card.
    • Insert a plastic opening tool between the seams of the device and pry the back cover away from the phone.
    • Remove the battery and SIM card.
  2. Remove the twelve screws using the Phillips 000 screwdriver.
    • Remove the twelve screws using the Phillips 000 screwdriver.
  3. Kostenloser Versand für alle Bestellungen über 100,00 $ oder mit einem Pro Tech Toolkit!
    Schau dich im Store um
    Erfolgreich repariert? Genial!
    Teile ein Foto deiner Reparatur mit dem Hashtag #ImAGenius
    Wir sind alle Genies
  4. Remove bottom plate where the charger port is located.
    • Remove bottom plate where the charger port is located.
  5. Insert a plastic opening tool between the seams of the device and apply some pressure to lift off the cover. Insert a plastic opening tool between the seams of the device and apply some pressure to lift off the cover.
    • Insert a plastic opening tool between the seams of the device and apply some pressure to lift off the cover.
  6. Flip over to the face of the device.
    • Flip over to the face of the device.
    • Lift off the glass screen (display).
  7. Remove the home screen button. Replace as needed.
    • Remove the home screen button. Replace as needed.
Abschluss
Ein weiterer Nutzer hat diese Anleitung absolviert.
Bruna
527 Reputation
4 Anleitungen geschrieben
USF Tampa, Team 9-1, Leahy Fall 2014 Mitglied von USF Tampa, Team 9-1, Leahy Fall 2014
USFT-LEAHY-F14S9G1
3 Mitglieder
5 Anleitungen geschrieben
in the step 2, one red ring is in the wrong position.
The ring in the midle at the left side is in the center of the telephone
Tiago - Antwort
Statistik anzeigen:
Letzte 24 Stunden: 0
Letzte 7 Tage: 3
Letzte 30 Tage: 8
Insgesamt: 1,634
