Einleitung
Is the back camera of the device not working properly? Time to replace it with a new and better one! Follow this easy and quick guide!
Was du brauchst
Insert a plastic opening tool between the seams of the device and pry the back cover away from the phone.
Remove the battery and SIM card.
Starting from the right, remove the attached black mount using the plastic spudger.
Apply some pressure on the back of the mount to detach the camera.
Replace the camera as needed.
