Zum Hauptinhalt wechseln
LG Optimus L7 P705 SIM Card Slot Replacement
Was du brauchst
  1. LG Optimus L7 P705 SIM Card Slot Replacement, Home Button: Schritt 1, Bild 1 von 2 LG Optimus L7 P705 SIM Card Slot Replacement, Home Button: Schritt 1, Bild 2 von 2
    • Insert a plastic opening tool between the seams of the device and pry the back cover away from the phone.
    • Remove the battery and SIM card.
  2. LG Optimus L7 P705 SIM Card Slot Replacement: Schritt 2, Bild 1 von 1
    • Remove the twelve screws using the Phillips 000 screwdriver.
  3. LG Optimus L7 P705 SIM Card Slot Replacement: Schritt 3, Bild 1 von 1
    • Remove bottom plate where the charger port is located.
  4. LG Optimus L7 P705 SIM Card Slot Replacement: Schritt 4, Bild 1 von 2 LG Optimus L7 P705 SIM Card Slot Replacement: Schritt 4, Bild 2 von 2
    • Insert a plastic opening tool between the seams of the device and apply some pressure to lift off the cover.
  5. LG Optimus L7 P705 SIM Card Slot Replacement: Schritt 5, Bild 1 von 1
    • Flip over to the face of the device.
    • Lift off the glass screen (display).
  6. LG Optimus L7 P705 SIM Card Slot Replacement: Schritt 6, Bild 1 von 1
    • Remove the home screen button. Replace as needed.
  7. LG Optimus L7 P705 SIM Card Slot Replacement, SIM Card Slot: Schritt 7, Bild 1 von 2 LG Optimus L7 P705 SIM Card Slot Replacement, SIM Card Slot: Schritt 7, Bild 2 von 2
    • Flip over to the back of the device
    • Using the plastic spudger, lift off the three board-to-board connectors on the left-hand side of the device.
  8. LG Optimus L7 P705 SIM Card Slot Replacement: Schritt 8, Bild 1 von 1
    • Using a plastic spudger, lift off the wire connector at the right bottom of the board.
  9. LG Optimus L7 P705 SIM Card Slot Replacement: Schritt 9, Bild 1 von 2 LG Optimus L7 P705 SIM Card Slot Replacement: Schritt 9, Bild 2 von 2
    • Detach the mount including both the SIM card and the motherboard from the device.
Abschluss
Yanxiang Ding
101 Reputation
1 Anleitung geschrieben
IUPUI, Team 2-2, Baechle Spring 2017 Mitglied von IUPUI, Team 2-2, Baechle Spring 2017
IUPUI-BAECHLE-S17S2G2
4 Mitglieder
3 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 1
Letzte 30 Tage: 9
Insgesamt: 633
