Einleitung
This guide will detail how to replace the Micro-USB Port on the LG Optimus L9 P769
Was du brauchst
Power off the device and gently lift the battery cover off to access the battery
Lift and remove the battery from the notch in the edge of the battery compartment
Remove all 10 of the 4.5mm screws that hold the back frame to the case of the phone using a PH000 screwdriver.
Using a small prying tool, carefully remove the back frame by prying on the sides of the device.
Remove 1.8mm screw to free Micro-USB module for removal using the PH000 headtype
Use a small prying tool to detach the Micro-USB circuitry from the case of the phone
