Zum Hauptinhalt wechseln
LG Optimus L9 P769 Micro-USB Port Replacement
Was du brauchst
  1. LG Optimus L9 P769 Micro-USB Port Replacement, Micro-USB Port: Schritt 1, Bild 1 von 1
    • Power off the device and gently lift the battery cover off to access the battery
  2. LG Optimus L9 P769 Micro-USB Port Replacement: Schritt 2, Bild 1 von 1
    • Lift and remove the battery from the notch in the edge of the battery compartment
  3. LG Optimus L9 P769 Micro-USB Port Replacement: Schritt 3, Bild 1 von 2 LG Optimus L9 P769 Micro-USB Port Replacement: Schritt 3, Bild 2 von 2
    • Remove all 10 of the 4.5mm screws that hold the back frame to the case of the phone using a PH000 screwdriver.
  4. LG Optimus L9 P769 Micro-USB Port Replacement: Schritt 4, Bild 1 von 2 LG Optimus L9 P769 Micro-USB Port Replacement: Schritt 4, Bild 2 von 2
    • Using a small prying tool, carefully remove the back frame by prying on the sides of the device.
    • Do be careful when prying back frame and removing it as too much force may result in damaging the frame.
  5. LG Optimus L9 P769 Micro-USB Port Replacement: Schritt 5, Bild 1 von 3 LG Optimus L9 P769 Micro-USB Port Replacement: Schritt 5, Bild 2 von 3 LG Optimus L9 P769 Micro-USB Port Replacement: Schritt 5, Bild 3 von 3
    In diesem Schritt verwendetes Werkzeug:
    Kaufen
    • Remove both connections of the antenna by pulling up with tweezers
  6. LG Optimus L9 P769 Micro-USB Port Replacement: Schritt 6, Bild 1 von 3 LG Optimus L9 P769 Micro-USB Port Replacement: Schritt 6, Bild 2 von 3 LG Optimus L9 P769 Micro-USB Port Replacement: Schritt 6, Bild 3 von 3
    • Remove Micro-USB Cache by unscrewing both 2.9mm screws with the PH000 headtype
  7. LG Optimus L9 P769 Micro-USB Port Replacement: Schritt 7, Bild 1 von 1
    • Detach module from motherboard using a prying tool
  8. LG Optimus L9 P769 Micro-USB Port Replacement: Schritt 8, Bild 1 von 2 LG Optimus L9 P769 Micro-USB Port Replacement: Schritt 8, Bild 2 von 2
    • Remove 1.8mm screw to free Micro-USB module for removal using the PH000 headtype
  9. LG Optimus L9 P769 Micro-USB Port Replacement: Schritt 9, Bild 1 von 2 LG Optimus L9 P769 Micro-USB Port Replacement: Schritt 9, Bild 2 von 2
    • Use a small prying tool to detach the Micro-USB circuitry from the case of the phone
  10. LG Optimus L9 P769 Micro-USB Port Replacement: Schritt 10, Bild 1 von 1
    • Comparison showing the Micro-USB module against the empty phone casing
Abschluss
Kayden G
272 Reputation
2 Anleitungen geschrieben
IUPUI, Team S2-G1, Harley Spring 2017 Mitglied von IUPUI, Team S2-G1, Harley Spring 2017
IUPUI-HARLEY-S17S2G1
4 Mitglieder
6 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 1
Letzte 30 Tage: 9
Insgesamt: 327
