Zum Hauptinhalt wechseln
LG Optimus L9 P769 Rear Facing Camera Replacement
Was du brauchst
  1. LG Optimus L9 P769 Rear Facing Camera Replacement, Removing the Back Panel: Schritt 1, Bild 1 von 2 LG Optimus L9 P769 Rear Facing Camera Replacement, Removing the Back Panel: Schritt 1, Bild 2 von 2
    • Pry the back panel from the frame of the phone to reveal the motherboard.
  2. LG Optimus L9 P769 Rear Facing Camera Replacement, Unpluging the Motherboard: Schritt 2, Bild 1 von 3 LG Optimus L9 P769 Rear Facing Camera Replacement, Unpluging the Motherboard: Schritt 2, Bild 2 von 3 LG Optimus L9 P769 Rear Facing Camera Replacement, Unpluging the Motherboard: Schritt 2, Bild 3 von 3
    • Detach the connectors on the motherboard.
  3. LG Optimus L9 P769 Rear Facing Camera Replacement, Unpluging the Motherboard Cont.: Schritt 3, Bild 1 von 3 LG Optimus L9 P769 Rear Facing Camera Replacement, Unpluging the Motherboard Cont.: Schritt 3, Bild 2 von 3 LG Optimus L9 P769 Rear Facing Camera Replacement, Unpluging the Motherboard Cont.: Schritt 3, Bild 3 von 3
    • Continue to lift the connectors off the motherboard.
  4. LG Optimus L9 P769 Rear Facing Camera Replacement, Lifting Motherboard from the Phone: Schritt 4, Bild 1 von 3 LG Optimus L9 P769 Rear Facing Camera Replacement, Lifting Motherboard from the Phone: Schritt 4, Bild 2 von 3 LG Optimus L9 P769 Rear Facing Camera Replacement, Lifting Motherboard from the Phone: Schritt 4, Bild 3 von 3
    • Lift the speaker cable off the motherboard.
    • Lift the motherboard up. It will Still be connected to the frame.
  5. LG Optimus L9 P769 Rear Facing Camera Replacement, Pry and remove the camera: Schritt 5, Bild 1 von 3 LG Optimus L9 P769 Rear Facing Camera Replacement, Pry and remove the camera: Schritt 5, Bild 2 von 3 LG Optimus L9 P769 Rear Facing Camera Replacement, Pry and remove the camera: Schritt 5, Bild 3 von 3
    • Pry under the camera to lift it off the frame.
    • There is some adhesive that will keep it attached to the frame, pulling the camera off will not damage the phone.
    • The camera should now be entirely separated from the phone.
Abschluss
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
Paul
145 Reputation
4 Anleitungen geschrieben
USF Tampa, Team 8-1, Leahy Fall 2014 Mitglied von USF Tampa, Team 8-1, Leahy Fall 2014
USFT-LEAHY-F14S8G1
4 Mitglieder
5 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 1
Letzte 30 Tage: 9
Insgesamt: 973
