Einleitung
Use this guide to replace the rear-facing camera of your LG Optimus L90.
Was du brauchst
Carefully slide an opening pick between the the rear cover and the body of the phone.
Using the pick, separate the cover from the back of the phone.
Remove the rear cover.
Insert a plastic opening tool int o the small recess at the bottom of the battery.
Use the plastic opening tool to lift up the bottom of the battery.
Remove the battery from the phone.
Disconnect the camera cable from its socket on the motherboard.
Remove the rear-facing camera.
2 weitere Nutzer:innen haben diese Anleitung absolviert.
