Zum Hauptinhalt wechseln
LG Optimus T Camera and Camera Mount Replacement
Was du brauchst
  1. LG Optimus T Camera and Camera Mount Replacement, Camera: Schritt 1, Bild 1 von 2 LG Optimus T Camera and Camera Mount Replacement, Camera: Schritt 1, Bild 2 von 2
    • Working on your device while it is turned on may result in electric shock. Make sure to shut down your device before you begin.
    • Use a plastic opening tool to remove the phone's back cover. At the top of the phone there are indentations to insert the spudger and pop the case off
  2. LG Optimus T Camera and Camera Mount Replacement: Schritt 2, Bild 1 von 1
    • Remove the battery by pulling up on the battery using the indentation to the left of the camera lens
  3. LG Optimus T Camera and Camera Mount Replacement: Schritt 3, Bild 1 von 1
    • Use a J0 screwdriver to remove the 6 highlighted screws
  4. LG Optimus T Camera and Camera Mount Replacement: Schritt 4, Bild 1 von 2 LG Optimus T Camera and Camera Mount Replacement: Schritt 4, Bild 2 von 2
    • Remove interior case using indentations on the top and bottom to insert the spudger to pop off the interior case
    • You might have difficulty popping the interior case off. You may use the metal spudger here with caution if the plastic one fails
  5. LG Optimus T Camera and Camera Mount Replacement: Schritt 5, Bild 1 von 1
    • Unhook the connector tab
  6. LG Optimus T Camera and Camera Mount Replacement: Schritt 6, Bild 1 von 1
    • Remove SD card mount by inserting the plastic opening tool on the right side of the device to pop mount off
  7. LG Optimus T Camera and Camera Mount Replacement: Schritt 7, Bild 1 von 2 LG Optimus T Camera and Camera Mount Replacement: Schritt 7, Bild 2 von 2
    • Remove metal panel by inserting plastic opening tool into the four retaining points and remove panel
  8. LG Optimus T Camera and Camera Mount Replacement: Schritt 8, Bild 1 von 1
    In diesem Schritt verwendetes Werkzeug:
    Kaufen
    • disconnect camera connector from motherboard by spudger
    • Once disconnected, remove camera using tweezers
Abschluss
stacey
219 Reputation
2 Anleitungen geschrieben
Ohio State, Team 1-3, Wilder Spring 2017 Mitglied von Ohio State, Team 1-3, Wilder Spring 2017
OSU-WILDER-S17S1G3
4 Mitglieder
5 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 9
Insgesamt: 121
