Zum Hauptinhalt wechseln
LG Optimus T Motherboard Replacement
Was du brauchst
  1. LG Optimus T Motherboard Replacement, Motherboard: Schritt 1, Bild 1 von 3 LG Optimus T Motherboard Replacement, Motherboard: Schritt 1, Bild 2 von 3 LG Optimus T Motherboard Replacement, Motherboard: Schritt 1, Bild 3 von 3
    • Working on your device while it is turned on may result in electric shock. Make sure to shut down and unplug your device before you begin.
    • Using a prying device, such as a plastic opening tool, remove the phone’s back cover. At the top of the phone, there’s an indentation to put the Spudger into to pop the case off
  2. LG Optimus T Motherboard Replacement: Schritt 2, Bild 1 von 1
    • Remove the battery. There’s an indentation to the left of the camera lens to pull up on the battery with your finger
  3. LG Optimus T Motherboard Replacement: Schritt 3, Bild 1 von 1
    • Use a J0 screwdriver to remove the six 4.5mm screws.
  4. LG Optimus T Motherboard Replacement: Schritt 4, Bild 1 von 2 LG Optimus T Motherboard Replacement: Schritt 4, Bild 2 von 2
    • You might have difficulty popping the interior case off. You may use the metal spudger here with caution if the plastic opening tool fails
    • Remove interior case. Insert the spudger into the indentations at the top, or bottom of the phone to pry off the interior case.
  5. LG Optimus T Motherboard Replacement: Schritt 5, Bild 1 von 1
    • Pull up on connector tab
  6. LG Optimus T Motherboard Replacement: Schritt 6, Bild 1 von 2 LG Optimus T Motherboard Replacement: Schritt 6, Bild 2 von 2
    • Remove SD card mount. Insert the plastic opening tool on the right side to pop off
  7. LG Optimus T Motherboard Replacement: Schritt 7, Bild 1 von 2 LG Optimus T Motherboard Replacement: Schritt 7, Bild 2 von 2
    • Remove metal panel
    • There are four retaining points to insert plastic opening tool and pop off panel
  8. LG Optimus T Motherboard Replacement: Schritt 8, Bild 1 von 1
    • Use a J0 screwdriver to remove the two 1.8mm screws from charging port. (Charging port and motherboard are connected.)
    • Remove motherboard
Abschluss
Eine weitere Person hat diese Anleitung absolviert.
stacey
219 Reputation
2 Anleitungen geschrieben
Ohio State, Team 1-3, Wilder Spring 2017 Mitglied von Ohio State, Team 1-3, Wilder Spring 2017
OSU-WILDER-S17S1G3
4 Mitglieder
5 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 2
Letzte 30 Tage: 10
Insgesamt: 308
