Einleitung
If your LG Optimus T will not turn on, or the battery will not charge replacing the motherboard may solve these issues.
Was du brauchst
Using a prying device, such as a plastic opening tool, remove the phone’s back cover. At the top of the phone, there’s an indentation to put the Spudger into to pop the case off
Remove the battery. There’s an indentation to the left of the camera lens to pull up on the battery with your finger
Remove interior case. Insert the spudger into the indentations at the top, or bottom of the phone to pry off the interior case.
Remove SD card mount. Insert the plastic opening tool on the right side to pop off
Remove metal panel
There are four retaining points to insert plastic opening tool and pop off panel
Use a J0 screwdriver to remove the two 1.8mm screws from charging port. (Charging port and motherboard are connected.)
Remove motherboard
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
