Was du brauchst
Using the plastic opening tool to remove the phone’s back cover. At the top of the phone, there’s an indentation to put the tool into to pop the case off.
Remove interior case. There are indentations on the top and bottom of the phone. Using a spudger, remove the interior case.
Using a spudger, gently pry off the metal panel on the back of the screen attached by 4 retaining points.
Remove the screen from the front of your device.
