Einleitung
If you own a LG Optimus V smartphone and notice that the sound quality has deteriorated, or there’s no sound at all, it's possible that the speaker has been damaged or has worn out over time. In such cases, replacing the speaker is a practical solution to restore the sound quality of your device. This guide will provide you with step-by-step instructions on how to replace the speaker in your LG Optimus V, and bring your device back to life.
Was du brauchst
Remove the six screws on the silver casing.
Use the plastic opening tool to remove the silver casing.
Use a plastic opening tool to remove the small black and yellow piece that reads Y3114C.
Use a plastic opening tool to pry off the camera.
To fix the speaker, use a soldering iron to heat up the two areas where the wires connect to the motherboard. Then, remove the old speaker and replace it with a new one by soldering it back onto the same areas.
Eine weitere Person hat diese Anleitung absolviert.
