Einleitung
The motherboard of the LG Optimus Zone 3 is a circuit board that is the backbone of the phone. It is responsible for connecting various parts of the phone and allows for communication between these parts so your device can function properly.
Was du brauchst
Insert fingernail into the slot on the back left side of the phone and pry open.
Insert the plastic opening tool into the groove between the screen and the rest of the device. Work your way around the perimeter by sliding the opening tool around the edge, loosening the screen.
Once the screen is loosened, fully remove it from the device by peeling it away from the base of the phone.
Insert plastic opening tool into groove between display and body of the phone. Work your way around the edges to loosen the display, and finally remove it with your fingers.
On the back side of the phone, loosen the bottom shield using the plastic opening tool, and remove it from the device.
On the back side of the phone, remove the upper shield using the plastic opening tool.
On the front side of the phone, push down on the top plastic shield to loosen it, and remove the shield using the plastic opening tool .
On the front side of the phone, push up on the plastic bottom shield using the plastic opening tool and remove it.
Using the plastic opening tool, work your way around the perimeter of the blue motherboard to loosen it from the body of the phone.
Using your fingers, grab onto the blue motherboard and safely remove the loosened motherboard from the device.
Ein Kommentar
I have yet to see this disassembly performed in a video online without incurring damage to the digitizer. All the videos show removal of the digitizer (cracking and splintering as they go), then the LCD. It looks like its not possible to remove them together due to the amount of adhesive LG uses under the digitizer at the top and bottom of the phone. It is unlikely that the digitizer would remain undamaged during the removal process regardless. Maybe if the adhesive is heated enough without melting the frame it may come willingly.
Anyone care to demonstrate otherwise?
So with that in mind it looks like I’ll need to order another digitizer before I pull a good LCD and (soon to be broken) good digitizer from a donor phone to replace the broken pair in my phone.
Just sayin’
