Einleitung
This guide will walk you through the process of replacing a battery in an LG Phoenix 2. A battery replacement may be needed if the phone loses charge faster than it did when it was new. A battery replacement may also be needed if the phone only works when it is plugged in and does not hold a charge at all.
The battery model used in this phone is a BL-46ZH battery.
  1. Place a fingernail in the notch at the bottom edge of the phone.
    • Place a fingernail in the notch at the bottom edge of the phone.
    • Pull on the back cover with one hand while keeping the rest of the phone steady, and run your fingernail along the edge.
  2. Place a fingernail in the notch at the bottom edge of the battery.
    • Place a fingernail in the notch at the bottom edge of the battery.
    • Pull the battery out.
Abschluss
Esteban Ruibal
Mitglied seit 14.02.2018
684 Reputation
5 Anleitungen geschrieben
USF Tampa, Team S2-G2, Eyestone Spring 2018 Mitglied von USF Tampa, Team S2-G2, Eyestone Spring 2018
USFT-EYESTONE-S18S2G2
4 Mitglieder
Statistik anzeigen:
Letzte 24 Stunden: 2
Letzte 7 Tage: 7
Letzte 30 Tage: 38
Insgesamt: 306
