Einleitung
If you need to install a new headphone jack on your LG Phoenix 2, use this guide to disassemble and replace the damaged part. For this guide you will need a plastic opening tool and a Phillips #000 screwdriver. These steps will be straightforward and easy to follow, but the pieces should be handled with care, so as to not damage or misplace any needed components.
Was du brauchst
Insert a fingernail into the notch on the bottom right corner of the phone.
Pop off the back cover off of your device.
Insert the opening tool in between the phone screen and the silver trim.
Pop off the trim.
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
