Einleitung
This guide will walk you through the process of replacing a speaker in an LG Phoenix 2. A speaker replacement may be needed if no sound comes out of the speaker.
The speaker model used in this phone is a KRP621 W1P speaker.
Was du brauchst
Place a fingernail in the notch at the bottom edge of the phone.
Pull on the back cover with one hand while keeping the rest of the phone steady, and run your fingernail along the edge.
Place a fingernail in the notch at the bottom edge of the battery.
Pull the battery out.
Locate the SIM card in the top right corner on the back of the phone.
Remove the SIM card by pushing it with your thumb from left to right.
Remove all 9 screws on the back by using a Phillips head #J00 screwdriver.
To remove the screws rotate them counterclockwise.
Insert a plastic opening tool in the split at the bottom of the phone (between the bottom shield and the rest of the phone).
Pry the bottom shield to separate it from the phone.
Once it is loose you should be able to remove it with your hand.
Insert the flat end of the Spudger between the screen and the chromed frame.
Once inserted, run the Spudger along the frame to separate the front part of the phone from the back shield.
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
