Einleitung
Before continuing, make sure you power down your device to prevent data loss or damage.
Was du brauchst
To remove the back, insert thumbnail into MicroUSB port, and pull up to loosen back.
Use nail to loosen case on all four sides. Once loose, remove back case.
3 weitere Nutzer:innen haben diese Anleitung absolviert.
