Zum Hauptinhalt wechseln
LG Realm Rear Facing Camera Replacement
Was du brauchst
  1. LG Realm Rear Facing Camera Replacement, Battery: Schritt 1, Bild 1 von 2 LG Realm Rear Facing Camera Replacement, Battery: Schritt 1, Bild 2 von 2
    • To remove the back, insert thumbnail into MicroUSB port, and pull up to loosen back.
    • Use nail to loosen case on all four sides. Once loose, remove back case.
  2. LG Realm Rear Facing Camera Replacement: Schritt 2, Bild 1 von 1
    • Insert thumbnail into tab below battery.
    • Pull away from phone and remove.
  3. LG Realm Rear Facing Camera Replacement, Plastic Midframe: Schritt 3, Bild 1 von 2 LG Realm Rear Facing Camera Replacement, Plastic Midframe: Schritt 3, Bild 2 von 2
    • Once the back cover and battery are removed, use the Phillips #J000 screwdriver to remove all 11 screws located around the plastic midframe.
  4. LG Realm Rear Facing Camera Replacement: Schritt 4, Bild 1 von 1
    • Using the plastic opening tool, carefully pry and separate the plastic midframe from the rest of the phone.
  5. LG Realm Rear Facing Camera Replacement, Rear Facing Camera: Schritt 5, Bild 1 von 1
    • Locate the rear facing camera.
    • Using the plastic opening tool, pry apart the cable from where it connects to the phone.
  6. LG Realm Rear Facing Camera Replacement: Schritt 6, Bild 1 von 1
    • After removing the ribbon cable, the camera should be easy to remove with your fingers. Remove the rear facing camera.
Abschluss
2 weitere Nutzer:innen haben diese Anleitung absolviert.
Marist, Team 1-5, Laflen Spring 2016 Mitglied von Marist, Team 1-5, Laflen Spring 2016
MARS-LAFLEN-S16S1G5
2 Mitglieder
10 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 5
Letzte 30 Tage: 15
Insgesamt: 267
