Zum Hauptinhalt wechseln
LG Rebel 4 LTE Disassembly
Was du brauchst
  1. LG Rebel 4 LTE Disassembly, Remove the Cover: Schritt 1, Bild 1 von 2 LG Rebel 4 LTE Disassembly, Remove the Cover: Schritt 1, Bild 2 von 2
    • Locate the indent on the back left side of the phone.
    • Insert the opening tool into the indent and pry until it pops.
    • Remove the backing.
  2. LG Rebel 4 LTE Disassembly, Remove Internal Components: Schritt 2, Bild 1 von 3 LG Rebel 4 LTE Disassembly, Remove Internal Components: Schritt 2, Bild 2 von 3 LG Rebel 4 LTE Disassembly, Remove Internal Components: Schritt 2, Bild 3 von 3
    • Use the spudger to pry the battery out.
    • If installed, pop out the SD/TF card by gently pressing in and releasing the SD card. Not pictured, Located above the Sims card (See Below).
    • Use your fingers to remove the sim card.
  3. LG Rebel 4 LTE Disassembly, Remove Screws: Schritt 3, Bild 1 von 3 LG Rebel 4 LTE Disassembly, Remove Screws: Schritt 3, Bild 2 von 3 LG Rebel 4 LTE Disassembly, Remove Screws: Schritt 3, Bild 3 von 3
    • Using the #000 Phillips screwdriver, remove all the screws (as seen in the photo).
    • There should be 12 screws in total.
    • Don't lose the screws!
  4. LG Rebel 4 LTE Disassembly, Remove Charging Port Cover: Schritt 4, Bild 1 von 2 LG Rebel 4 LTE Disassembly, Remove Charging Port Cover: Schritt 4, Bild 2 von 2
    • Use the spudger to carefully pry the cover around the charging port.
  5. LG Rebel 4 LTE Disassembly, Remove the Screen: Schritt 5, Bild 1 von 3 LG Rebel 4 LTE Disassembly, Remove the Screen: Schritt 5, Bild 2 von 3 LG Rebel 4 LTE Disassembly, Remove the Screen: Schritt 5, Bild 3 von 3
    • Rotate the phone (view picture) to reveal the top corner of the phone.
    • Using a opening pick, pry in between the glass screen and the framing.
  6. LG Rebel 4 LTE Disassembly, Remove the Motherboard: Schritt 6, Bild 1 von 3 LG Rebel 4 LTE Disassembly, Remove the Motherboard: Schritt 6, Bild 2 von 3 LG Rebel 4 LTE Disassembly, Remove the Motherboard: Schritt 6, Bild 3 von 3
    • Pry from the top and bottom of the screen with the (refer to photo) opening pick to release the tabs holding the motherboard to the phone.
    • Do not let the main camera fall out while removing the mother board.
  7. LG Rebel 4 LTE Disassembly, Disconnect the Connector Cable: Schritt 7, Bild 1 von 3 LG Rebel 4 LTE Disassembly, Disconnect the Connector Cable: Schritt 7, Bild 2 von 3 LG Rebel 4 LTE Disassembly, Disconnect the Connector Cable: Schritt 7, Bild 3 von 3
    • On the bottom right of the phone, locate a cable that holds the motherboard to the phone.
    • Disconnect the cable by gently pulling up on the component with your fingers.
    • Do not use a prying tool or screwdriver to disconnect the cable.
  8. LG Rebel 4 LTE Disassembly, Remove the Camera: Schritt 8, Bild 1 von 3 LG Rebel 4 LTE Disassembly, Remove the Camera: Schritt 8, Bild 2 von 3 LG Rebel 4 LTE Disassembly, Remove the Camera: Schritt 8, Bild 3 von 3
    • Separate the camera from the magnet by gently pulling up.
  9. LG Rebel 4 LTE Disassembly, Disassembly Complete: Schritt 9, Bild 1 von 1
    • Congratulations. You've successfully disassembled your device.
    • To reassemble the device, follow these steps in reverse order. (Begin with step 8, continuining until you end on step 1.
    • When reassembling, make sure that each component snaps tightly to the phone before moving to the next step.
Abschluss
JCJR
169 Reputation
1 Anleitung geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 8
Letzte 30 Tage: 19
Insgesamt: 174
